Ana içeriğe geç
Yardım
OLPC XO-4 Touch Keyboard Replacement
This guide will show you how to remove and install a keyboard.
Use this guide to replace a broken keyboard.
Bölümler
Aletler
Adım 1 Keyboard  ¶
Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs. Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
Adım 1 Keyboard  ¶
  • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
Adım 2  ¶
Flip the laptop over to its normal position. Lift the two antennas on both sides to unlock the screen. Open the laptop.
Adım 2  ¶
  • Flip the laptop over to its normal position.
  • Lift the two antennas on both sides to unlock the screen.
  • Open the laptop.
Adım 3  ¶
Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom. Gently lift up on the back of the keyboard.
Adım 3  ¶
  • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
  • Gently lift up on the back of the keyboard.
  • Pull the keyboard up far enough to expose the ribbon cable.
Adım 4  ¶
Gently lift up on the black connector to release the ribbon cable. Gently pull the blue plastic tab up and away from the black connector.
Adım 4  ¶
  • Gently lift up on the black connector to release the ribbon cable.
  • Gently pull the blue plastic tab up and away from the black connector.
  • Remove the keyboard from the laptop.
