Ana içeriğe geç
Yardım
iBook G3 12" DC-In Board Replacement
  • Yazar: iRobot
  • Tahmini süre: 1 saat
  • Zorluk: Zor
Tripped over your power cord? At least you don't have to replace the entire logic board.
Bölümler
Dosyalar
Adım 1 DC-In Board  ¶
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Adım 2  ¶
Remove the single 5.5 mm Phillips screw securing the DC-In board to the metal framework.
Adım 2  ¶
  • Remove the single 5.5 mm Phillips screw securing the DC-In board to the metal framework.
Adım 3  ¶
Peel up the DC-In cable from the bottom of the metal framework and pull it through the conveniently-located nearby hole.
Adım 3  ¶
  • Peel up the DC-In cable from the bottom of the metal framework and pull it through the conveniently-located nearby hole.
