Ana içeriğe geç
Yardım
iMac Intel 27" EMC 2546 Right Speaker Replacement
Replace your iMac's right speaker.
Missing half your beats? Replace the right speaker to bring back your stereo sound.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
Bölümler
Aletler
Adım 1 Right Speaker  ¶
Remove two 10.0 mm T10 screws.
  • Remove two 10.0 mm T10 screws.
Adım 2  ¶
Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board. Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Adım 2  ¶
  • Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Adım 3  ¶
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board. Pull the connector to the right to remove it from its socket. Pull the connector to the right to remove it from its socket.
Adım 3  ¶
  • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
  • Pull the connector to the right to remove it from its socket.
Adım 4  ¶
Lift the speaker straight up and remove it from the iMac. Lift the speaker straight up and remove it from the iMac. Lift the speaker straight up and remove it from the iMac.
Adım 4  ¶
  • Lift the speaker straight up and remove it from the iMac.
