Ana içeriğe geç
Yardım
iMac Intel 27" EMC 2546 SATA Cable Replacement
Tehlikeli Olma Potansiyeli Var
Bu talimat doğru şekilde uygulanmazsa yaralanma meydana gelebilir. Dikkatli olun ve tüm uyarıları takip edin.
Remove the SATA cable from your Late 2012 27" iMac.
Use this guide to remove the SATA cable.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Bölümler
Aletler
Adım 1 SATA Cable  ¶
Pull up on the SATA power cable connector to disconnect it. Unplug the SATA data cable connector by lifting it up. Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
Adım 1 SATA Cable  ¶
  • Pull up on the SATA power cable connector to disconnect it.
  • Unplug the SATA data cable connector by lifting it up.
  • Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
