Ana içeriğe geç
Yardım
MacBook Pro 15" Unibody Mid 2009 Lower Case Replacement
Remove the lower case to access most of your MacBook Pro's internals.
Adım 1 Lower Case  ¶
Remove the following ten screws securing the lower case to the upper case:
Adım 1 Lower Case  ¶
  • Seven 3 mm Phillips screws.
Adım 2  ¶
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case. Remove the lower case and set it aside.
Adım 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
