Ana içeriğe geç
Yardım
iBook G4 14" 933 MHz-1.33 GHz Display Replacement
Change out the entire display assembly, including the inverter, Airport antenna, hinges and plastic casing.
Bölümler
Adım 1 Display  ¶
Turn the computer over.
Adım 1 Display  ¶
  • Turn the computer over.
  • Disconnect the inverter cable from the logic board and deroute it from the metal framework, removing tape as necessary.
Adım 2  ¶
Turn the computer back over.
Adım 2  ¶
  • Turn the computer back over.
  • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using a spudger or a small flathead screwdriver if necessary.
  • Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework.
Adım 3  ¶
Use the black plastic loop to disconnect the display data cable from the logic board.
Adım 3  ¶
  • Use the black plastic loop to disconnect the display data cable from the logic board.
Adım 4  ¶
Deroute the microphone and display data cables from the metal framework, removing tape as necessary.
Adım 4  ¶
  • Deroute the microphone and display data cables from the metal framework, removing tape as necessary.
Adım 5  ¶
Deroute the AirPort antenna cable from the metal framework, removing tape as necessary.
Adım 5  ¶
  • Deroute the AirPort antenna cable from the metal framework, removing tape as necessary.
Adım 6  ¶
Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
Adım 6  ¶
  • Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
  • The screws go in the outer holes on each side (you can see the threads in the correct hole).
Adım 7  ¶
Lift the display up and tilt it backwards, freeing it from the two metal alignment posts holding the hinges in place, and slide it away from you.
Adım 7  ¶
  • Lift the display up and tilt it backwards, freeing it from the two metal alignment posts holding the hinges in place, and slide it away from you.
