Ana içeriğe geç
Yardım
Rival Mini Chopper MC-67BL Power Cord Replacement
Remove the power cord of the Rival Mini Chopper.
  • Yazar: Roxanne
  • Tahmini süre: 30 dakika
  • Zorluk: Zor
This guide will help you remove the power cord and requires the use of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
Aletler (devam)
İlgili Parçalar
Adım 1 Power Cord  ¶
Use your hand to firmly pull the blade-shaft from the base.
Adım 1 Power Cord  ¶
  • Use your hand to firmly pull the blade-shaft from the base.
Adım 2  ¶
Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
Adım 2  ¶
  • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
Adım 3  ¶
Unwind power cord from the base pegs.
Adım 3  ¶
  • Unwind power cord from the base pegs.
Adım 4  ¶
Use the plastic opening tool to pry open the base from the main body. These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
Adım 4  ¶
  • Use the plastic opening tool to pry open the base from the main body.
  • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
  • Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
Adım 5  ¶
Pull the power cord wires up from underneath the wire hook on the side of the motor.
Adım 5  ¶
  • Pull the power cord wires up from underneath the wire hook on the side of the motor.
Adım 6  ¶
Carefully cut into black wire casing for both wires using a small knife and peel away the black casing. Only cut deep enough to remove the casing.
Adım 6  ¶
  • Carefully cut into black wire casing for both wires using a small knife and peel away the black casing.
  • Only cut deep enough to remove the casing.
  • For reassembly you will need black electrical tape to keep the wires from being exposed.
Adım 7  ¶
Using a soldering kit, remove the solder for the black power cord from the circuit board.
Adım 7  ¶
  • Using a soldering kit, remove the solder for the black power cord from the circuit board.
  • Follow this soldering guide if you need extra help!
Adım 8  ¶
Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
Adım 8  ¶
  • Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
  • For reassembly the copper wires will need to be soldered together.
