Ana içeriğe geç
Yardım
Game Boy Micro Motherboard Replacement
Adım Kırpıcı
Adım Kırpıcı
Bu kılavuzda gereksiz adımlar mevcut. Az ve öz olması için kırpın!
Tutarsız Görseller
Tutarsız Görseller
Bu kılavuzdaki görselleri ön koşullarla daha tutarlı olacak şekilde güncellemek, kusursuzluğunuza katkıda bulunacaktır.
In this guide, we will show you how to remove and replace the motherboard and LCD.
Bölümler
Adım 1 Motherboard  ¶
The LCD screen is connected to the motherboard by two ribbon cables. Use a plastic spudger to disconnect the LCD's ZIF connector. Use a plastic spudger to disconnect the LCD's ZIF connector.
  • The LCD screen is connected to the motherboard by two ribbon cables.
  • Use a plastic spudger to disconnect the LCD's ZIF connector.
Adım 2  ¶
Use the tip of the spudger to lift the small, black tab holding the thin ribbon. With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen. With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen.
Adım 2  ¶
  • Use the tip of the spudger to lift the small, black tab holding the thin ribbon.
  • With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen.
