Ana içeriğe geç
Yardım
Nokia 6010 screen and speaker replacement
Use this guide to remove and replace the Nokia 6010's LCD screen and speaker.
Bölümler
Adım 1 LCD Screen and Speaker  ¶
Remove the six screws around the front of the phone body with a T6 screwdriver. Remove the six screws around the front of the phone body with a T6 screwdriver.
  • Remove the six screws around the front of the phone body with a T6 screwdriver.
Adım 2  ¶
Insert your finger underneath the speaker piece and pry away from the phone body. The plastic layer containing the LCD screen and speaker takes some force to remove. There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
Adım 2  ¶
  • Insert your finger underneath the speaker piece and pry away from the phone body.
  • The plastic layer containing the LCD screen and speaker takes some force to remove.
  • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
  • The LCD and the speaker are attached to the same piece and must be replaced together.
