Ana içeriğe geç
Yardım
Texas Instruments TI-92 Teardown
Teardown
Teardown
Teardown'lar device içerisine bakmanızı sağlar ve söküm talimatları olarak kullanılmamalıdır.
Provided is an exploded view of the TI-92 calculator. All dis-assembled components are the back-side of the parts.
Adım 1 Texas Instruments TI-92 Teardown  ¶
Remove the protective cover. This will easily unsnap from the main body.
  • Remove the protective cover. This will easily unsnap from the main body.
Adım 2  ¶
Slide the tab located at the top of the calculator to the unlocked position.
Adım 2  ¶
  • Slide the tab located at the top of the calculator to the unlocked position.
Adım 3  ¶
Slide the back cover down, and then pull the back plate away from the calculator.
Adım 3  ¶
  • Slide the back cover down, and then pull the back plate away from the calculator.
Adım 4  ¶
Unscrew the back-up battery cover. (1 screw)
Adım 4  ¶
  • Unscrew the back-up battery cover. (1 screw)
Adım 5  ¶
Remove all visible screws.
Adım 5  ¶
  • Remove all visible screws.
  • Note that there are more screws than shown in this picture (16 in total). You MUST remove them ALL.
Adım 6  ¶
Keeping the front faceplate FACE DOWN on the work surface, lift the circuit board AND the plastic backing up and away from the faceplate.
Adım 6  ¶
  • Keeping the front faceplate FACE DOWN on the work surface, lift the circuit board AND the plastic backing up and away from the faceplate.
Adım 7  ¶
These two components are loosely attached by the rectangular module just below the back-up battery.
Adım 7  ¶
  • These two components are loosely attached by the rectangular module just below the back-up battery.
Adım 8  ¶
The warning label next to this module reads "Do not remove the rectangular module located under the test access panel as it is required for proper product operation!"
Adım 8  ¶
  • The warning label next to this module reads "Do not remove the rectangular module located under the test access panel as it is required for proper product operation!"
Adım 9  ¶
The rubber mat in back of the faceplate may be removed, exposing all 77 individual plastic keys.
Adım 9  ¶
  • The rubber mat in back of the faceplate may be removed, exposing all 77 individual plastic keys.
  • CAUTION: These keys are loosely held in by gravity and will fall out if the faceplate is tilted to any extreme.
Adım 10  ¶
The device has now been separated into as many component parts as intended by the manufacturer.
Adım 10  ¶
  • The device has now been separated into as many component parts as intended by the manufacturer.
