Ana içeriğe geç
Yardım
Linksys BEFW11S4 Teardown
Teardown
Teardown
Teardown'lar device içerisine bakmanızı sağlar ve söküm talimatları olarak kullanılmamalıdır.
Üye Katkılı Kılavuz
Üye Katkılı Kılavuz
Topluluğumuzun müthiş bir üyesi bu kılavuzu hazırladı. Bu kılavuz, iFixit personeli tarafından yönetilmiyor.
This wireless router stopped working, so I wanted to take a look at it's innards.
Adım 1 Linksys BEFW11S4 Teardown  ¶
Waiting to be disassembled...
  • Waiting to be disassembled...
Adım 2  ¶
Remove antennas. Remove nuts and washers around antenna connectors. Push in antenna connectors.
Adım 2  ¶
  • Remove antennas.
  • Remove nuts and washers around antenna connectors.
  • Push in antenna connectors.
Adım 3  ¶
Remove feet (with flat-head screwdriver, fingernails, etc). Unscrew the screws. Unscrew the screws.
Adım 3  ¶
  • Remove feet (with flat-head screwdriver, fingernails, etc).
  • Unscrew the screws.
Adım 4  ¶
Pull apart blue front from black back with a LOT of force. Slide and pull up bottom. (Make sure the antenna connectors get through.)
Adım 4  ¶
  • Pull apart blue front from black back with a LOT of force.
  • Slide and pull up bottom. (Make sure the antenna connectors get through.)
Adım 5  ¶
Twist and pull out antenna connector feeds.
Adım 5  ¶
  • Twist and pull out antenna connector feeds.
Adım 6  ¶
Pull up RF shield from motherboard. Unscrew the motherboard from the bottom. Push the motherboard forward (as in this picture) to unlatch it from the bottom.
Adım 6  ¶
  • Pull up RF shield from motherboard.
  • Unscrew the motherboard from the bottom.
  • Push the motherboard forward (as in this picture) to unlatch it from the bottom.
Adım 7  ¶
Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router. Push the card forward to deattach the pins.
Adım 7  ¶
  • Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
  • Push the card forward to deattach the pins.
  • Remove the card from the metal holdster.
Adım 8  ¶
Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
Adım 8  ¶
  • Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
  • Macronix 29F040QC-90
  • ISSI IS41C16100S-50K
  • SAMSUNG ARM S3C4510X01-QERO
  • RMC RTL8019AS
  • Bothhands FB2022
  • Bothhands 40ST1041E
  • Kendin KS8995. Kendin has since been bought by Micrel.
Adım 9  ¶
Enjoy!
Adım 9  ¶
  • Enjoy!
