Ana içeriğe geç
Yardım
Mr. Coffee TF6 Internal Water Tubes Replacement
This guide provides step-by-step directions on how to replace the water tubes inside the Mr. Coffee TF6.
Leaks can occur within the Mr. Coffee TF6. In most cases, replacing the internal water tubes will correct this issue. You will require 2 inches of silicone tubing (.5 in. OD) to replace the original water tubes inside the TF6.
Adım 1 Internal Water Tubes  ¶
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
  • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
Adım 2  ¶
Carefully pull the silicon tubing off of the metal tubing.
Adım 2  ¶
  • Carefully pull the silicon tubing off of the metal tubing.
Adım 3  ¶
Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
Adım 3  ¶
  • Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
Adım 4  ¶
Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
Adım 4  ¶
  • Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
  • If all screws have been removed and the tubes have been detached, the assemblies should separate easily.
Adım 5  ¶
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
Adım 5  ¶
  • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
Adım 6  ¶
Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Adım 6  ¶
  • Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
