Ana içeriğe geç
Yardım
Kodak Easyshare C813 Memory Card Replacement
This guide demonstrates how to install a memory card.
Adım 1 Memory Card  ¶
Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
Adım 2  ¶
Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow. Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow. Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
Adım 2  ¶
  • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
Adım 3  ¶
Locate memory card slot and insert memory card by inserting the gold terminals first. Apply pressure into you feel it lock into place.
Adım 3  ¶
  • Locate memory card slot and insert memory card by inserting the gold terminals first.
  • Apply pressure into you feel it lock into place.
  • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
Adım 4  ¶
Return the battery door to its formerly closed position. Return the battery door to its formerly closed position.
Adım 4  ¶
  • Return the battery door to its formerly closed position.
Adım 5  ¶
Turn on camera.
Adım 5  ¶
