Ana içeriğe geç
Yardım
Gateway SA1 Outer Casing Replacement
İşlem Görüntüleri
İşlem Görüntüleri
Öykünün yıldızı olun! Belirli eylemlerin nasıl gerçekleştirileceğini daha iyi göstermek için bu kılavuza resimler gerekli.
  • Yazar: Diego Carteno
  • Tahmini süre: 10 - 15 dakika
  • Zorluk: Orta
Procedure for dissembling the outer casing of the laptop safely.
Bölümler
Aletler
Adım 1 Outer Casing  ¶
Remove the twelve 5.9 mm Philips screws from the back cover.
  • Remove the twelve 5.9 mm Philips screws from the back cover.
  • Remove one 8.8 mm Philips screw from the back cover.
Adım 2  ¶
Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery. Unscrew the three 3.6 mm Philips screws that are within the Disk drive port. Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
Adım 2  ¶
  • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
  • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
Adım 3  ¶
Remove the hinge covers by lifting each with the sharp point of the spudger. Notice that the middle cover has a different shape and is more difficult to remove.
Adım 3  ¶
  • Remove the hinge covers by lifting each with the sharp point of the spudger.
  • Notice that the middle cover has a different shape and is more difficult to remove.
Adım 4  ¶
There will be a connection underneath the speaker cover. Remove the speaker cover using the spudger. Remove the speaker cover using the spudger.
Adım 4  ¶
  • There will be a connection underneath the speaker cover.
  • Remove the speaker cover using the spudger.
Adım 5  ¶
Unscrew the two 3.9 mm Philips screws and remove the keyboard.
Adım 5  ¶
  • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
Adım 6  ¶
Carefully lift the keyboard off from the laptop. It is still attached as shown. Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away. The brown colored component with the tabs does not come out with the connector.
Adım 6  ¶
  • Carefully lift the keyboard off from the laptop. It is still attached as shown.
  • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
  • The brown colored component with the tabs does not come out with the connector.
Adım 7  ¶
Lift up the black tab and gently pull out the connector. Lift up the black tab and gently pull out the connector. Lift up the black tab and gently pull out the connector.
Adım 7  ¶
  • Lift up the black tab and gently pull out the connector.
Adım 8  ¶
Unscrew the four marked 5.9 mm Philips screws. Unscrew the four marked 5.9 mm Philips screws.
Adım 8  ¶
  • Unscrew the four marked 5.9 mm Philips screws.
Adım 9  ¶
Move the wires out of the fixed space as shown. Move the wires out of the fixed space as shown.
Adım 9  ¶
  • Move the wires out of the fixed space as shown.
Adım 10  ¶
Unscrew the five marked 3.8 mm Philips screws. Three screws are located on the right side of the screen.
Adım 10  ¶
  • Unscrew the five marked 3.8 mm Philips screws.
  • Three screws are located on the right side of the screen.
  • Two screws are located on the left side of the screen.
Adım 11  ¶
Remove the screen brackets from the computer's base.
Adım 11  ¶
  • Remove the screen brackets from the computer's base.
Adım 12  ¶
Remove the four 5.9 mm Philips screws as indicated: There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo. There are two similarly positioned screws on the right side.
Adım 12  ¶
  • Remove the four 5.9 mm Philips screws as indicated:
  • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
  • There are two similarly positioned screws on the right side.
Adım 13  ¶
The following steps (18 - 20) explain how to remove the three indicated connections. The order is Blue, Violet, Orange.
Adım 13  ¶
  • The following steps (18 - 20) explain how to remove the three indicated connections.
  • The order is Blue, Violet, Orange.
  • Lift the white tab up and gently take out the connector.
Adım 14  ¶
Use the spudger to pull off the black attachment.
Adım 14  ¶
  • Use the spudger to pull off the black attachment.
Adım 15  ¶
Lift and pull the black tab upward until it becomes unattached.
Adım 15  ¶
  • Lift and pull the black tab upward until it becomes unattached.
  • Some force may be required.
Adım 16  ¶
Use the spudger to remove the casing as seen in the picture.
Adım 16  ¶
  • Use the spudger to remove the casing as seen in the picture.
Adım 17  ¶
Remove the casing.
Adım 17  ¶
  • Remove the casing.
