Ana içeriğe geç
Yardım
Toshiba Satellite L305D-S5950 Battery Replacement
Daha İyi Resimler Gerekli
Daha iyi fotoğraflar bu kılavuzu geliştirecektir. Yeni fotoğraflar çekerek, düzenleyerek ya da yükleyerek katkıda bulunun!
This guide will help you through replacing your battery.
  • Yazar: William
  • Tahmini süre: 1 dakika
  • Zorluk: Çok kolay
This guide illustrates how to replace the battery of the Toshiba Satellite L305D-S5950.
Aletler
Adım 1 Battery  ¶
Locate the two sliding battery locks on the underside of the laptop.
Adım 1 Battery  ¶
  • Locate the two sliding battery locks on the underside of the laptop.
Adım 2  ¶
Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
Adım 2  ¶
  • Locate the right battery lock and slide it to the right.
Adım 3  ¶
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Adım 3  ¶
  • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Adım 4  ¶
Remove the battery from the laptop.
Adım 4  ¶
  • Remove the battery from the laptop.
