Ana içeriğe geç
Yardım
Toshiba Satellite L305-S5875 CCFL Tube Replacement
Tehlikeli Olma Potansiyeli Var
Bu talimat doğru şekilde uygulanmazsa yaralanma meydana gelebilir. Dikkatli olun ve tüm uyarıları takip edin.
This guide will help show you how to replace a CCFL tube that is no longer functioning for the Toshiba Satellite L305-S5875 model laptop.
  • Yazar: Tyler
  • Tahmini süre: 45 dakika
  • Zorluk: Orta
Welcome to the Toshiba Satellite L305-S5875 CCFL Tube Replacement guide page. This guide uses both visual and written instructions in a step by step manner to help you replace the damaged CCFL tube in your screen with a brand new one.
Adım 1 CCFL Tube  ¶
With the screen now removed from the computer, remove the two screws from the screen's metal enclosure. In addition to removing the screws, remove the tape on the edge of the screen.
Adım 1 CCFL Tube  ¶
  • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
  • In addition to removing the screws, remove the tape on the edge of the screen.
Adım 2  ¶
Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure. Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube. Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
Adım 2  ¶
  • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
  • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
Adım 3  ¶
With the bad CCFL tube now accessible, very carefully remove it from the screen housing. With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
Adım 3  ¶
  • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
  • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
  • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
