Ana içeriğe geç
Yardım
Toshiba A1304T Main LCD Screen Replacement
İşlem Görüntüleri
İşlem Görüntüleri
Öykünün yıldızı olun! Belirli eylemlerin nasıl gerçekleştirileceğini daha iyi göstermek için bu kılavuza resimler gerekli.
Daha İyi Resimler Gerekli
Daha iyi fotoğraflar bu kılavuzu geliştirecektir. Yeni fotoğraflar çekerek, düzenleyerek ya da yükleyerek katkıda bulunun!
  • Yazar: Christopher
  • Tahmini süre: 20 - 30 dakika
  • Zorluk: Orta
This guide covers the removal of the main LCD screen and associated housing from the Toshiba A1304T for replacement.
Adım 1 Main LCD Screen  ¶
Using the head of the flathead screwdriver, gently pry the black tab so that it rests in a vertical (or "unlocked") position. Pull the orange ribbon-wire to the left, removing it from the white socket.
  • Using the head of the flathead screwdriver, gently pry the black tab so that it rests in a vertical (or "unlocked") position.
  • Pull the orange ribbon-wire to the left, removing it from the white socket.
Adım 2  ¶
Just as before, use the head of the flathead screwdriver to pry the black tab into a vertical position, as shown.
Adım 2  ¶
  • Just as before, use the head of the flathead screwdriver to pry the black tab into a vertical position, as shown.
  • Pull the ribbon wire to the right, freeing it from its socket.
Adım 3  ¶
Using the head of the flathead screwdriver, pry the silver plastic casing of the LCD from the video logic board. Repeat as necessary around the device until the silver plastic casing is free.
Adım 3  ¶
  • Using the head of the flathead screwdriver, pry the silver plastic casing of the LCD from the video logic board.
  • Repeat as necessary around the device until the silver plastic casing is free.
  • Attempting to further separate the LCD screen from the silver plastic casing will likely result in severe damage to the screen.
