Ana içeriğe geç
Yardım
PlayStation 4 Motherboard Replacement
Öne Çıkan Öğrenci Kılavuzu
Bu kılavuz, çalışkan öğrencilerimizin alın teriyle üretildi ve iFixit kadrosu tarafından epey havalı bulunuyor.
Replacement of the motherboard, including the HDMI port.
If you are having an issue with the motherboard (or any of its ports: HDMI, USB, etc.) and need to replace it, this is the guide for you. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty
Removing the motherboard separates the original thermal paste between the processor and the heat sink. Before you reassemble your device, reapply a new layer of thermal paste. Follow this guide to learn how.
Adım 1 Motherboard  ¶
Flip the PS4 upside down on its top.
  • Flip the PS4 upside down on its top.
Adım 2  ¶
Remove the four stickers from the back of the PS4. Removing any of these stickers voids your warranty with Sony.
Adım 2  ¶
  • Remove the four stickers from the back of the PS4.
  • Removing any of these stickers voids your warranty with Sony.
Adım 3  ¶
Remove the four 9mm TR9 Security Torx screws from the back of the PS4.
Adım 3  ¶
  • Remove the four 9mm TR9 Security Torx screws from the back of the PS4.
Adım 4  ¶
With the device upside down, lift up on the back side of the device to remove the bottom cover.
Adım 4  ¶
  • With the device upside down, lift up on the back side of the device to remove the bottom cover.
Adım 5  ¶
Remove the three 9mm TR9 Security Torx  screws on the power supply.
Adım 5  ¶
  • Remove the three 9mm TR9 Security Torx screws on the power supply.
  • Remove the two 4mm Phillips #1 screws.
Adım 6  ¶
Disconnect the power supply connector from the power supply. Lift the power supply unit to remove it from the case.
Adım 6  ¶
  • Disconnect the power supply connector from the power supply.
  • Lift the power supply unit to remove it from the case.
Adım 7  ¶
Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire.  This should not require force. Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
Adım 7  ¶
  • Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
  • Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
Adım 8  ¶
Unplug the optical drive cord from the motherboard.
Adım 8  ¶
  • Unplug the optical drive cord from the motherboard.
Adım 9  ¶
Remove the wifi cord from the motherboard.
Adım 9  ¶
  • Remove the wifi cord from the motherboard.
Adım 10  ¶
Remove the four 9mm TR9 Security Torx  screws.
Adım 10  ¶
  • Remove the four 9mm TR9 Security Torx screws.
  • Remove the 5mm Phillips #1 screw.
Adım 11  ¶
Remove the wifi antenna.
Adım 11  ¶
  • Remove the wifi antenna.
Adım 12  ¶
Lift the optical drive up and remove it from the system.
Adım 12  ¶
  • Lift the optical drive up and remove it from the system.
Adım 13  ¶
Flip the system over and remove the left top panel by pressing it back and lifting up.
Adım 13  ¶
  • Flip the system over and remove the left top panel by pressing it back and lifting up.
Adım 14  ¶
Remove the two 9mm TR9 Security Torx screws.
Adım 14  ¶
  • Remove the two 9mm TR9 Security Torx screws.
Adım 15  ¶
Pull out and remove the hard drive from the system.
Adım 15  ¶
  • Pull out and remove the hard drive from the system.
Adım 16  ¶
Lift up on the front of the top cover and slide backwards.
Adım 16  ¶
  • Lift up on the front of the top cover and slide backwards.
Adım 17  ¶
Remove the twelve 9mm TR9 Security Torx screws.
Adım 17  ¶
  • Remove the twelve 9mm TR9 Security Torx screws.
Adım 18  ¶
Remove the two 9mm Phillips head #1 screws. Remove the metal  support bracket.
Adım 18  ¶
  • Remove the two 9mm Phillips head #1 screws.
  • Remove the metal support bracket.
Adım 19  ¶
Lift up and remove the metal covering.
Adım 19  ¶
  • Lift up and remove the metal covering.
Adım 20  ¶
Disconnect the three wire plug from the motherboard by gently prying upwards and away from the motherboard. Disconnect the three wire plug from the motherboard by gently prying upwards and away from the motherboard.
Adım 20  ¶
  • Disconnect the three wire plug from the motherboard by gently prying upwards and away from the motherboard.
Adım 21  ¶
Lift up and remove the motherboard from the system.
Adım 21  ¶
  • Lift up and remove the motherboard from the system.
  • Removing the motherboard separates the original thermal paste between the processor and the heat sink. Before you reassemble your device, reapply a new layer of thermal paste. Follow this guide to learn how.
