Ana içeriğe geç
Yardım
Dell Inspiron 1750 RAM Replacement
This guide will help you replace the RAM (random access memory) chip on your Dell Inspiron 1750.
  • Yazar: Tina Rickard
  • Tahmini süre: 10 dakika
  • Zorluk: Kolay
It is useful to to replace the hard drive if your computer has become slow or if your programs freeze or crash.
Adım 1 RAM  ¶
Remove the one 2mm Phillips #00 screw on the module cover. Use the plastic opening tool to lift the module cover. Use the plastic opening tool to lift the module cover.
Adım 1 RAM  ¶
  • Remove the one 2mm Phillips #00 screw on the module cover.
  • Use the plastic opening tool to lift the module cover.
Adım 2  ¶
Pull the metal tabs away from the RAM chip to release it from the motherboard. Pull the chip up from the laptop.
Adım 2  ¶
  • Pull the metal tabs away from the RAM chip to release it from the motherboard.
  • Pull the chip up from the laptop.
  • Use the plastic opening tool to lift the chip out if it's difficult to do with your hands.
  • Repeat this process for the RAM chip directly beneath the last one.
