Ana içeriğe geç
Yardım
BlackBerry Pearl 8100 Keyboard Replacement
İşlem Görüntüleri
İşlem Görüntüleri
Öykünün yıldızı olun! Belirli eylemlerin nasıl gerçekleştirileceğini daha iyi göstermek için bu kılavuza resimler gerekli.
Follow this guide to install the keyboard in the Blackberry Pearl 8100.
Bölümler
Aletler
Adım 1 Keyboard  ¶
Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
Adım 1 Keyboard  ¶
  • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
Adım 2  ¶
Using the spudger, pry off the small portion of the casing located at the bottom of the phone. Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
Adım 2  ¶
  • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
Adım 3  ¶
Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
Adım 3  ¶
  • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
Adım 4  ¶
Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
Adım 4  ¶
  • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
Adım 5  ¶
Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face.  Remove the back body panel. Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face.  Remove the back body panel.
Adım 5  ¶
  • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
Adım 6  ¶
Separate the logic board from the front panel.
Adım 6  ¶
  • Separate the logic board from the front panel.
Adım 7  ¶
Gently remove the keyboard from front casing. It should snap out of place. Gently remove the keyboard from front casing. It should snap out of place.
Adım 7  ¶
  • Gently remove the keyboard from front casing. It should snap out of place.
