Ana içeriğe geç
Yardım
Sony Vaio PCG-7184L (VGN-NW240F) Back Panel Removal
This guide will detail the steps to removing the back panel of the Sony Vaio PCG-7184L
  • Yazar: Sid
  • Tahmini süre: 5 - 15 dakika
  • Zorluk: Kolay
Removing the back panel on the laptop allows access to the inner components.
Adım 1 Back Panel  ¶
Remove all the 8mm Phillips #1 screws on the backside of the laptop. There are three 3mm and two 5.3mm screws under the battery that also need to be taken out. There are three 3mm screws under the optical drives that also need to be taken out.
Adım 1 Back Panel  ¶
  • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
  • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
  • There are three 3mm screws under the optical drives that also need to be taken out.
  • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Adım 2  ¶
Pry along the edges of the back panel using the spudger. If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again. If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
Adım 2  ¶
  • Pry along the edges of the back panel using the spudger.
  • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
