Ana içeriğe geç
Yardım
Sony Vaio PCG-7A2L Hard Drive Replacement
This guide will show you how to replace the Hard Drive on your Sony Vaio PCG-7A2L.
Bölümler
Aletler
Adım 1 Hard Drive  ¶
Locate and remove the screw (Length: 7.7mm) for the hard drive cover. Slide the cover until it is free from the laptop case. Lift the cover to remove.
Adım 1 Hard Drive  ¶
  • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
  • Slide the cover until it is free from the laptop case.
  • Lift the cover to remove.
Adım 2  ¶
Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place. Using the tab on the tray, slide the Hard Drive away from the main body of the laptop. The Hard Drive should now be disconnected.
Adım 2  ¶
  • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
  • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
  • The Hard Drive should now be disconnected.
  • Lift the drive out with the tab on the tray.
