Ana içeriğe geç
Yardım
RIDGID R84015 X2 Disassembly
Adım Kırpıcı
Adım Kırpıcı
Bu kılavuzda gereksiz adımlar mevcut. Az ve öz olması için kırpın!
This guide explains how to disassemble the casing of a RIDGID R84015 X2 power drill.
  • Yazar: Brian
  • Tahmini süre: 5 dakika
  • Zorluk: Orta
Follow these steps to disassemble the plastic casing of the RIDGID R84015 X2 power drill.
Adım 1 RIDGID R84015 X2 Disassembly  ¶
With your drill taken apart, move your attention to the trigger and forward reverse switch.
  • With your drill taken apart, move your attention to the trigger and forward reverse switch.
Adım 2  ¶
Check to see that the forward reverse switch isn't broken.
Adım 2  ¶
  • Check to see that the forward reverse switch isn't broken.
  • NOTE: small tab on trigger fits into groove on forward reverse switch
Adım 3  ¶
With the battery attached, check that the wires work when the trigger is pulled.
Adım 3  ¶
  • With the battery attached, check that the wires work when the trigger is pulled.
  • Put multimeter wires here.
  • If wires work and drill doesn't, the problem is with the motor.
Adım 4  ¶
Make sure plastic is not broken and switch is not stuck.
Adım 4  ¶
  • Make sure plastic is not broken and switch is not stuck.
Adım 5  ¶
Looks good, doesn't it?
Adım 5  ¶
  • Looks good, doesn't it?
