Ana içeriğe geç
Yardım
MacBook Pro 13" Retina Display Late 2013 Trackpad Replacement
Replace the Trackpad in your MacBook Pro 13" Retina Display Late 2013.
Use this guide to replace the trackpad. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Adım 1 Trackpad  ¶
Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
Adım 1 Trackpad  ¶
  • Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
  • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
Adım 2  ¶
Use a plastic opening tool to carefully pry the trackpad cover plate up from the upper case. Go slowly and carefully to avoid putting any visible creases in the plate. Go slowly and carefully to avoid putting any visible creases in the plate.
Adım 2  ¶
  • Use a plastic opening tool to carefully pry the trackpad cover plate up from the upper case.
  • Go slowly and carefully to avoid putting any visible creases in the plate.
Adım 3  ¶
Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case. Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case. Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case.
Adım 3  ¶
  • Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case.
Adım 4  ¶
Gently peel the plate up to remove it. Gently peel the plate up to remove it.
Adım 4  ¶
  • Gently peel the plate up to remove it.
Adım 5  ¶
If necessary, peel back any tape covering the trackpad cable connector.
Adım 5  ¶
  • If necessary, peel back any tape covering the trackpad cable connector.
Adım 6  ¶
Use the tip of a spudger to flip the retaining tab on the ZIF connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Adım 6  ¶
  • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Adım 7  ¶
Pull the trackpad ribbon cable straight out of its socket on the logic board.
Adım 7  ¶
  • Pull the trackpad ribbon cable straight out of its socket on the logic board.
Adım 8  ¶
Wedge the flat end of a spudger underneath the upper case opening where the trackpad ribbon cable passes is routed through. Gently pry the trackpad ribbon cable from the adhesive securing it to the upper case.
Adım 8  ¶
  • Wedge the flat end of a spudger underneath the upper case opening where the trackpad ribbon cable passes is routed through.
  • Gently pry the trackpad ribbon cable from the adhesive securing it to the upper case.
Adım 9  ¶
Remove the following screws securing the trackpad brackets to the trackpad and upper case.
Adım 9  ¶
  • Remove the following screws securing the trackpad brackets to the trackpad and upper case.
  • Four 2.2 mm T5 Torx screws
  • Four 1.7 mm T5 Torx screws
Adım 10  ¶
Use tweezers to remove the two trackpad mounting brackets from the upper case. Use tweezers to remove the two trackpad mounting brackets from the upper case.
Adım 10  ¶
  • Use tweezers to remove the two trackpad mounting brackets from the upper case.
Adım 11  ¶
To avoid scratching the display, open the computer about 90º and set it on end. Carefully guide the trackpad ribbon cable through the slot cut in the upper case.
Adım 11  ¶
  • To avoid scratching the display, open the computer about 90º and set it on end.
  • Carefully guide the trackpad ribbon cable through the slot cut in the upper case.
  • This will push the trackpad up out of its recess in the top of the upper case.
  • Guide the trackpad out of the upper casewith your other hand, so it doesn't fall.
Adım 12  ¶
Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable.
Adım 12  ¶
  • Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable.
