Ana içeriğe geç
Yardım
MacBook Pro 13" Retina Display Late 2013 Upper Case Replacement
Replace the Upper Case in your MacBook Pro 13" Retina Display Late 2013.
Use this guide to replace the upper case. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Some replacement upper case assemblies may include the trackpad and battery as well. In this case, skip steps 18 through 44.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Adım 1 Upper Case  ¶
Carefully remove the rubber fan bumper from the edge of the heat sink. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
Adım 1 Upper Case  ¶
  • Carefully remove the rubber fan bumper from the edge of the heat sink.
  • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
Adım 2  ¶
Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws. Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Adım 2  ¶
  • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Adım 3  ¶
Remove the following screws securing the heat sink:
Adım 3  ¶
  • Remove the following screws securing the heat sink:
  • Four 2.6 mm T5 screws
  • One 2.4 mm Phillips #000 screw
  • In the Early 2015 model, this is a silver 2.7 mm T5 screw.
Adım 4  ¶
Remove the heat sink from the laptop. Use the thermal paste application guide to reapply the thermal paste before reassembly.
Adım 4  ¶
Adım 5  ¶
Use the tip of a spudger to push on either side of the the iSight camera cable connector and walk it out of its socket on the logic board. Use the tip of a spudger to push on either side of the the iSight camera cable connector and walk it out of its socket on the logic board.
Adım 5  ¶
  • Use the tip of a spudger to push on either side of the the iSight camera cable connector and walk it out of its socket on the logic board.
Adım 6  ¶
Peel the iSight camera cable up off the fan housing to fold it out of the way. Peel the iSight camera cable up off the fan housing to fold it out of the way.
Adım 6  ¶
  • Peel the iSight camera cable up off the fan housing to fold it out of the way.
Adım 7  ¶
Use the tip of a spudger to flip the tab on the fan's ZIF connector. Carefully pull the fan cable from its connector. Carefully pull the fan cable from its connector.
Adım 7  ¶
  • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
  • Carefully pull the fan cable from its connector.
Adım 8  ¶
Remove the following screws securing the fan to the upper case:
Adım 8  ¶
  • Remove the following screws securing the fan to the upper case:
  • One 5.0 mm T5 Torx screw
  • Two 3.6 mm T5 Torx screws
Adım 9  ¶
Lift the end of the fan from the heat sink cavity and pull it up and out toward the hinge of the laptop to remove it. Lift the end of the fan from the heat sink cavity and pull it up and out toward the hinge of the laptop to remove it. Lift the end of the fan from the heat sink cavity and pull it up and out toward the hinge of the laptop to remove it.
Adım 9  ¶
  • Lift the end of the fan from the heat sink cavity and pull it up and out toward the hinge of the laptop to remove it.
Adım 10  ¶
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
Adım 10  ¶
  • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
  • The three cables are coded with black sleeves of different lengths. During reassembly:
  • Connect the long-sleeved cable to the center socket.
  • The short-sleeved cable connects next to the screw.
  • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  • When reconnecting the antenna cables, run them over the camera cable, not underneath.
Adım 11  ¶
With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board. With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
Adım 11  ¶
  • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
Adım 12  ¶
Remove the following screws securing the I/O board to the upper case:
Adım 12  ¶
  • Remove the following screws securing the I/O board to the upper case:
  • One 3.5 mm T8 Torx standoff screw
  • One 3.5 mm T5 Torx screw
Adım 13  ¶
Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case. Remove the I/O board. When reinstalling the I/O board, be sure to slide the USB ports' metal EMI fingers under the side of the case, not over.
Adım 13  ¶
  • Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case.
  • Remove the I/O board.
  • When reinstalling the I/O board, be sure to slide the USB ports' metal EMI fingers under the side of the case, not over.
Adım 14  ¶
Use the flat end of a spudger to disconnect the keyboard backlight cable and move it out of the way. Use the flat end of a spudger to disconnect the keyboard backlight cable and move it out of the way.
Adım 14  ¶
  • Use the flat end of a spudger to disconnect the keyboard backlight cable and move it out of the way.
Adım 15  ¶
If necessary, peel back any tape covering the microphone cable ZIF connector. Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector. Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
Adım 15  ¶
  • If necessary, peel back any tape covering the microphone cable ZIF connector.
  • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
Adım 16  ¶
Pull the microphone cable straight out of its socket on the logic board.
Adım 16  ¶
  • Pull the microphone cable straight out of its socket on the logic board.
Adım 17  ¶
If necessary, peel back any tape covering the keyboard cable connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Adım 17  ¶
  • If necessary, peel back any tape covering the keyboard cable connector.
  • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Adım 18  ¶
Pull the keyboard cable straight out of its ZIF socket on the logic board.
Adım 18  ¶
  • Pull the keyboard cable straight out of its ZIF socket on the logic board.
Adım 19  ¶
Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
Adım 19  ¶
  • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
  • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
Adım 20  ¶
Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case and remove the logic board. When reinstalling, make sure the keyboard, keyboard backlight, and microphone cables don't get trapped beneath the logic board. Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
Adım 20  ¶
  • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case and remove the logic board.
  • When reinstalling, make sure the keyboard, keyboard backlight, and microphone cables don't get trapped beneath the logic board.
  • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
Adım 21  ¶
Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges. Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
Adım 21  ¶
  • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
Adım 22  ¶
Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case. Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
Adım 22  ¶
  • Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
Adım 23  ¶
Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
Adım 23  ¶
  • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
Adım 24  ¶
Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case. Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
Adım 24  ¶
  • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
Adım 25  ¶
Open the MacBook Pro a little wider than 90 degrees, and place it on end, as shown. While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
Adım 25  ¶
  • Open the MacBook Pro a little wider than 90 degrees, and place it on end, as shown.
  • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
  • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
  • Remove the last remaining T8 Torx screw securing the display to the upper case.
Adım 26  ¶
Grip both halves of the device, one in each hand. Gently push forward on the bottom half of the device to detach it from the display assembly. Carefully set each component aside, making sure to set down the lower half keyboard-side down.
Adım 26  ¶
  • Grip both halves of the device, one in each hand.
  • Gently push forward on the bottom half of the device to detach it from the display assembly.
  • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
Adım 27  ¶
Place the MacBook on a heated iOpener for about a minute to soften the adhesive securing the dual microphone cable.
Adım 27  ¶
  • Place the MacBook on a heated iOpener for about a minute to soften the adhesive securing the dual microphone cable.
Adım 28  ¶
Insert the tip of a spudger under the rubber microphone cable cover to free it form the upper case. Remove the rubber microphone cable cover. Remove the rubber microphone cable cover.
Adım 28  ¶
  • Insert the tip of a spudger under the rubber microphone cable cover to free it form the upper case.
  • Remove the rubber microphone cable cover.
Adım 29  ¶
Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case. Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case. Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case.
Adım 29  ¶
  • Insert the tip of a spudger under the connector end of the microphone ribbon cable and lift to peel that section up from the upper case.
Adım 30  ¶
Insert the tip of a spudger under the right-hand portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case. Insert the tip of a spudger under the right-hand portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case. Insert the tip of a spudger under the right-hand portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
Adım 30  ¶
  • Insert the tip of a spudger under the right-hand portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
Adım 31  ¶
Remove the microphone cable from the upper case.
Adım 31  ¶
  • Remove the microphone cable from the upper case.
