Ana içeriğe geç
Yardım
DualShock 4 Right Analog Stick Replacement
Üye Katkılı Kılavuz
Üye Katkılı Kılavuz
Topluluğumuzun müthiş bir üyesi bu kılavuzu hazırladı. Bu kılavuz, iFixit personeli tarafından yönetilmiyor.
Replacement of the analog joystick resolved the drift. No surprise and straight forward
  • Yazar: oldturkey03
  • Tahmini süre: 30 dakika - 1 saat
  • Zorluk: Orta
Here is a DualShock 4 controller that had a drift to both analog joysticks. Fairly straight forward replacement of the joysticks resolved the issue.
Adım 1 Right Analog Stick  ¶
These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right. Use a desoldering wick and flux to melt and remove the solder This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
  • These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right.
  • Use a desoldering wick and flux to melt and remove the solder
  • This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
Adım 2  ¶
Once all the contacts are desoldered, the old joystick can be removed. Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes. Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
Adım 2  ¶
  • Once all the contacts are desoldered, the old joystick can be removed.
  • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes.
  • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
Adım 3  ¶
Double check to make sure the joystick is seated properly. Solder all the contacts to the board. Here is the board after the repair. All that is left is to clean off the old flux with some isopropyl alcohol.
Adım 3  ¶
  • Double check to make sure the joystick is seated properly.
  • Solder all the contacts to the board.
  • Here is the board after the repair. All that is left is to clean off the old flux with some isopropyl alcohol.
