Ana içeriğe geç
Yardım
IBM ThinkPad T42 Battery Replacement
  • Yazar: Kevin Rehm
  • Tahmini süre: 5 dakika
  • Zorluk: Çok kolay
Changing the battery is easy -- you don't need a any tools.
Adım 1 Battery Clips  ¶
Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
  • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
  • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
Adım 2 Removing the Battery  ¶
Carefully grab the battery, then pull it straight out, not at an angle.
  • Carefully grab the battery, then pull it straight out, not at an angle.
