Ana içeriğe geç
Yardım
MacBook Unibody Model A1342 Rear Display Bezel Replacement
Replace a damaged rear display bezel to keep your MacBook looking new.
Replacing the rear display bezel requires removal of every component in your display.
Bölümler
Adım 1 Rear Display Bezel  ¶
Remove the two small pieces of black tape securing the antenna cables to the rear display bezel.
  • Remove the two small pieces of black tape securing the antenna cables to the rear display bezel.
Adım 2  ¶
Remove the four 2.3 mm Phillips screws securing the antennas to the rear display bezel.
Adım 2  ¶
  • Remove the four 2.3 mm Phillips screws securing the antennas to the rear display bezel.
Adım 3  ¶
Remove the single 3.3 mmm Phillips screw securing the lower antenna ground to the rear display bezel.
Adım 3  ¶
  • Remove the single 3.3 mmm Phillips screw securing the lower antenna ground to the rear display bezel.
Adım 4  ¶
De-route the antenna cables from the groove cut into the rear display bezel. Carefully pull the antenna cables out from under the frame attached to the rear display bezel and remove them from the display assembly.
Adım 4  ¶
  • De-route the antenna cables from the groove cut into the rear display bezel.
  • Carefully pull the antenna cables out from under the frame attached to the rear display bezel and remove them from the display assembly.
Adım 5  ¶
Remove the three Phillips screws securing the center antenna to the rear display bezel.
Adım 5  ¶
  • Remove the three Phillips screws securing the center antenna to the rear display bezel.
Adım 6  ¶
Remove the center antenna from the rear display bezel.
Adım 6  ¶
  • Remove the center antenna from the rear display bezel.
Adım 7  ¶
Remove the three 4.7 mm T6 Torx screws securing the right clutch hinge to the rear display bezel. Remove the right clutch hinge.
Adım 7  ¶
  • Remove the three 4.7 mm T6 Torx screws securing the right clutch hinge to the rear display bezel.
  • Remove the right clutch hinge.
Adım 8  ¶
Remove the three 4.7 mm T6 Torx screws securing the left clutch hinge to the rear display bezel. Remove the left clutch hinge.
Adım 8  ¶
  • Remove the three 4.7 mm T6 Torx screws securing the left clutch hinge to the rear display bezel.
  • Remove the left clutch hinge.
  • Rear display bezel remains.
