Ana içeriğe geç
Yardım
Blu Studio HD 6.0 Midframe Replacement
This guide if for removing the Blu Studio's battery panel.
  • Yazar: Erik reinbolt
  • Tahmini süre: 5 - 10 dakika
  • Zorluk: Kolay
In this guide you'll be opening the battery housing of your Blu Studio, this is the second step you'll take whenever you replace or add internal parts (excluding the SIMs and SD cards).
Either fingernails or plastic prying tools can be used for lifting once all the screws have been removed.
Adım 1 Midframe  ¶
With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00) With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
Adım 1 Midframe  ¶
  • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
Adım 2  ¶
Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
Adım 2  ¶
  • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
  • One of the lower right hand screws will be hidden under a sticker.
Adım 3  ¶
After removing all 16 screws you can begin the process of removing the battery housing panel.
Adım 3  ¶
  • After removing all 16 screws you can begin the process of removing the battery housing panel.
  • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
  • Try to be careful around the side buttons as the plastic is weakest there.
  • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
Adım 4  ¶
At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
Adım 4  ¶
  • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
