Ana içeriğe geç
Yardım
Garmin Nuvi 200 Rear Casing Replacement
This guide will show you how to install the casing of Garmin Nuvi 200.
Adım 1 Rear Casing  ¶
Peel off the sticker from the bottom of the device to reveal two screws. Peel off the sticker from the bottom of the device to reveal two screws.
  • Peel off the sticker from the bottom of the device to reveal two screws.
Adım 2  ¶
Remove two T5 Torx screws.
Adım 2  ¶
  • Remove two T5 Torx screws.
Adım 3  ¶
Insert a plastic opening tool in the gap between the front and rear casing. Carefully work the tool around the gap, separating the two halves of the case.
Adım 3  ¶
  • Insert a plastic opening tool in the gap between the front and rear casing.
  • Carefully work the tool around the gap, separating the two halves of the case.
  • Keep the power switch in place while removing the rear case.
