Ana içeriğe geç
Yardım
Sony Vaio PCG-981L Floppy Drive Replacement
Metin kafa karıştırıcı
Bu kılavuzdaki bazı metinler ya kafa karıştırıcı, ya tekrar edilmiş ya da konu dışı. Düzenleyerek daha açıklayıcı hale getirin!
Eksik önkoşulları
Eksik önkoşulları
Bu kılavuz, işleme nasıl başlanacağı ile ilgili bilgilere sahip değil. Bir önkoşul kılavuzu oluşturun!
Adım Kırpıcı
Adım Kırpıcı
Bu kılavuzda gereksiz adımlar mevcut. Az ve öz olması için kırpın!
The purpose is to open up the floppy drive so that you can check for any connection failures or damages.
  • Yazar: Loratious
  • Tahmini süre: 10 - 15 dakika
  • Zorluk: Kolay
If for any reason the floppy drive isn't working, the simplest solution is to replace the entire drive. But, if you're not able to aquire a new drive you may be able at least find the source of the failure through disassebling the drive.
Adım 1 Floppy Drive  ¶
Turn the copmuter over so that its underside is facing up. Then slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
  • Turn the copmuter over so that its underside is facing up. Then slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
Adım 2  ¶
Completely remove and isolate the floppy drive from the laptop.
Adım 2  ¶
  • Completely remove and isolate the floppy drive from the laptop.
Adım 3  ¶
There are two screws on each side (total of four screws) of the floppy drive. Remove these screws.
Adım 3  ¶
  • There are two screws on each side (total of four screws) of the floppy drive. Remove these screws.
Adım 4  ¶
Once you have removed the screws, you can remove the floppy drive core from its casing as shown.
Adım 4  ¶
  • Once you have removed the screws, you can remove the floppy drive core from its casing as shown.
Adım 5  ¶
After you have removed the floppy drive core from its casing, unscrew these five screws shown.
Adım 5  ¶
  • After you have removed the floppy drive core from its casing, unscrew these five screws shown.
Adım 6  ¶
Remove the two screws holding part of the floppy processinng unit.
Adım 6  ¶
  • Remove the two screws holding part of the floppy processinng unit.
Adım 7  ¶
Now that the screws are removed, you can remove the entire processing unit of the floppy drive.
Adım 7  ¶
  • Now that the screws are removed, you can remove the entire processing unit of the floppy drive.
Adım 8  ¶
Here is an isolated image of the core hardware of the floppy drive. Here is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to re solder some of the connections.
Adım 8  ¶
  • Here is an isolated image of the core hardware of the floppy drive. Here is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to re solder some of the connections.
Adım 9  ¶
Here is an isolated image of the floppy drive casing unit.
Adım 9  ¶
  • Here is an isolated image of the floppy drive casing unit.
