Ana içeriğe geç
Yardım
MacBook Pro 15" Unibody Mid 2010 Left Speaker Replacement
Replace a blown-out left speaker on your Mid 2010 MacBook Pro 15" Unibody.
Use this guide to replace a broken left speaker. Replacing the left speaker requires removal of the logic board.
Bölümler
Aletler
Adım 1 Left Speaker  ¶
Lift the microphone out of its recess in the left speaker housing.
  • Lift the microphone out of its recess in the left speaker housing.
Adım 2  ¶
Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
Adım 2  ¶
  • Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
Adım 3  ¶
If present, remove the small strip of black tape covering the left speaker connector.
Adım 3  ¶
  • If present, remove the small strip of black tape covering the left speaker connector.
  • Carefully pull the left speaker wires upward to lift the left speaker connector out of its socket on the logic board.
