Ana içeriğe geç
Yardım
Mac Mini Mid 2010 Bottom Cover Replacement
Removing the bottom cover.
  • Yazar: Andrew Bookholt
  • Tahmini süre: 15 saniye - 2 dakika
  • Zorluk: Çok kolay
Remove the bottom cover to access components inside your Mac mini Model A1347.
Adım 1 Bottom Cover  ¶
Place your thumbs in the depressions cut into the bottom cover. Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Adım 2  ¶
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
Adım 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
