Ana içeriğe geç
Yardım
Sony XPERIA Tablet Z Micro USB Port Replacement
Daha iyi giriş
Daha iyi giriş
Girişi tamamlayarak ya da daha iyi hale getirerek bu kılavuzu geliştirin.
Follow this guide to replace both the charging port and the USB port for your Sony Xperia Tablet Z.
  • Yazar: Martin Luna
  • Tahmini süre: 10 dakika
  • Zorluk: Orta
Adım 1 Micro USB Port  ¶
Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers. Insert plastic opening tool in the corner of device and slide along edges to separate adhesive. Remove cover
  • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
  • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
  • Remove cover
Adım 2  ¶
Located in the bottom left of the device you will remove the two screws holding the metal plate on the USB port. Remove metal plate Remove plastic securing the USB port.
Adım 2  ¶
  • Located in the bottom left of the device you will remove the two screws holding the metal plate on the USB port.
  • Remove metal plate
  • Remove plastic securing the USB port.
Adım 3  ¶
Remove screw with screw diver and lift metal plate with tweezers. Pick up left end of the electrical tape Lift up to remove USB plug from the mounting location.
Adım 3  ¶
  • Remove screw with screw diver and lift metal plate with tweezers.
  • Pick up left end of the electrical tape
  • Lift up to remove USB plug from the mounting location.
