Ana içeriğe geç
Yardım
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
Replace the front-facing camera and sensor cable in the iPhone 6.
  • Yazar: Sam Goldheart
  • Tahmini süre: 30 dakika - 1 saat
  • Zorluk: Orta
Use this guide to replace the front-facing camera and sensor cable including the front-facing camera, microphone and other sensors.
Note that the earpiece speaker is removed in this guide—be sure to save and transfer the earpiece speaker into your replacement cable assembly when you reassemble.
You can also use this guide to replace the following parts:
Adım 1 Front-Facing Camera and Sensor Cable  ¶
Keeping the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel. Keeping the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
  • Keeping the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
Adım 2  ¶
Fold the front-facing camera and sensor cable up to allow access to the microphone. Fold the front-facing camera and sensor cable up to allow access to the microphone.
Adım 2  ¶
  • Fold the front-facing camera and sensor cable up to allow access to the microphone.
Adım 3  ¶
Carefully pry the microphone end of the sensor cable off of the adhesive holding it to the front panel. Carefully pry the microphone end of the sensor cable off of the adhesive holding it to the front panel.
Adım 3  ¶
  • Carefully pry the microphone end of the sensor cable off of the adhesive holding it to the front panel.
Adım 4  ¶
Remove the front-facing camera and sensor cable from the front panel.
Adım 4  ¶
  • Remove the front-facing camera and sensor cable from the front panel.
