Ana içeriğe geç
Yardım
iPad 3G Communications Board Replacement
Replace your iPad 3G's communications board responsible for 3G connectivity.
Use this guide to replace your iPad 3G's communications board which is responsible for sending/receiving 3G data.
İlgili Parçalar
Adım 1 Communications Board  ¶
Use the edge of an iPod opening tool to carefully pry the remaining antenna connector up off the communications board.
  • Use the edge of an iPod opening tool to carefully pry the remaining antenna connector up off the communications board.
Adım 2  ¶
De-route the control button cable along the top edge of the communications board. Pull the communications cable upward to lift its connector up and out of the socket on the logic board.
Adım 2  ¶
  • De-route the control button cable along the top edge of the communications board.
  • Pull the communications cable upward to lift its connector up and out of the socket on the logic board.
Adım 3  ¶
Remove the single T5 Torx screw securing the communications board to the rear case.
Adım 3  ¶
  • Remove the single T5 Torx screw securing the communications board to the rear case.
Adım 4  ¶
If necessary, lift the right edge of the communications board upward to release it from the adhesive pad attached to the rear case. Pull the communications board away from its socket on the logic board.
Adım 4  ¶
  • If necessary, lift the right edge of the communications board upward to release it from the adhesive pad attached to the rear case.
  • Pull the communications board away from its socket on the logic board.
