Ana içeriğe geç
Yardım
Eureka AirSpeed Bagless Zuum Vacuum Hose Replacement
If there is no suction, this guide outlines the replacement of the major suction connection within the mechanism of the vacuum.
If you determine there is no suction at the end of the hose, this guide will help you to replace a damaged hose.
Adım 1 Hose  ¶
On the back of the vacuum, pull the handle connected to the hose away from the vacuum. On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Adım 1 Hose  ¶
  • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Adım 2  ¶
Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose. Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
Adım 2  ¶
  • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
