Ana içeriğe geç
Yardım
Apple Time Capsule Model A1302 Fan Replacement
Üye Katkılı Kılavuz
Üye Katkılı Kılavuz
Topluluğumuzun müthiş bir üyesi bu kılavuzu hazırladı. Bu kılavuz, iFixit personeli tarafından yönetilmiyor.
Learn how to replace the fan in your Apple Time Capsule Model A1302.
  • Yazar: rousp
  • Tahmini süre: 5 - 10 dakika
  • Zorluk: Orta
You are now going to:
  1. Open Your Time Capsule
  2. Remove the fan
  3. Install a new fan. Or re-install the old fan if you are like me, and do this for fun..
İlgili Parçalar
Adım 1 Fan  ¶
These three plastic plugs hold the fan in place. Use a plastic spudger or similar and press the plugs through the case to release the fan. Use a plastic spudger or similar and press the plugs through the case to release the fan.
Adım 1 Fan  ¶
  • These three plastic plugs hold the fan in place.
  • Use a plastic spudger or similar and press the plugs through the case to release the fan.
Adım 2  ¶
To re-seat your fan use a spudger or similar to force the plastic plugs back in the way they came out. This can be fiddly, but after a few tries you master it. If you are replacing your fan, make sure that the plastic plugs are included. Or be prepared to re-seat your fan using an alternative method like double sided tape or nuts and bolts.
Adım 2  ¶
  • To re-seat your fan use a spudger or similar to force the plastic plugs back in the way they came out. This can be fiddly, but after a few tries you master it.
  • If you are replacing your fan, make sure that the plastic plugs are included. Or be prepared to re-seat your fan using an alternative method like double sided tape or nuts and bolts.
