Ana içeriğe geç
Yardım
Samsung Gear Live Heart Rate Monitor Replacement
Adım Kırpıcı
Adım Kırpıcı
Bu kılavuzda gereksiz adımlar mevcut. Az ve öz olması için kırpın!
This guide will show you how to replace the heart rate monitor on the Samsung Gear Live.
The heart rate monitor is a component that allows your watch to read your heart rate. It does this by emitting infrared light to monitor blood flow under your skin. If your watch does not detect your heart rate and you've tried the options in the Troubleshooting guide, then the heart rate monitor may need to be replaced.
Bölümler
Adım 1 Remove the heart rate sensor cable  ¶
Set the motherboard on a flat, stable surface. Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
  • Set the motherboard on a flat, stable surface.
  • Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
Adım 2 Pry up the heart rate sensor  ¶
Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along. Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along. Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
  • Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
