Ana içeriğe geç
Yardım
JD Razor 2000 Quick-Release Lever Replacement
Daha iyi giriş
Daha iyi giriş
Girişi tamamlayarak ya da daha iyi hale getirerek bu kılavuzu geliştirin.
Replace the quick-release lever. The lever allows the scooter to collapse into a portable form. This guide will show the replacement process.
  • Yazar: Shane
  • Tahmini süre: 20 - 30 dakika
  • Zorluk: Kolay
Adım 1 Unlocking the Lever  ¶
Unlock the quick-release lever by turning the lever from a tightened position. Unlock the quick-release lever by turning the lever from a tightened position.
  • Unlock the quick-release lever by turning the lever from a tightened position.
Adım 2 Loosening the Screw  ¶
Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown. Be sure to fasten the opposite side of the screw before unscrewing. Remove the screw and note the order of the parts for reassembly.
  • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
  • Be sure to fasten the opposite side of the screw before unscrewing.
  • Remove the screw and note the order of the parts for reassembly.
Adım 3 Removing the Latch  ¶
Turn the quick-release lever over to reveal an 8mm screw. Use the Phillips #2 screw driver to remove the screw. After removing the screw, the circular latch will be detachable.
  • Turn the quick-release lever over to reveal an 8mm screw.
  • Use the Phillips #2 screw driver to remove the screw.
  • After removing the screw, the circular latch will be detachable.
