Ana içeriğe geç
Yardım
Samsung Galaxy Light Motherboard Replacement
Replace the motherboard.
Replace the motherboard on your Samsung Galaxy Light.
Adım 1 Unscrew Midframe  ¶
Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
Adım 2 Remove Midframe  ¶
Using the plastic opening tool, separate the midframe from the front panel of the device.
  • Using the plastic opening tool, separate the midframe from the front panel of the device.
  • Remove the midframe.
Adım 3 Detach Motherboard  ¶
To detach the motherboard from the device: Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard. Carefully lift the motherboard up and move it toward the left side of the device.
  • To detach the motherboard from the device:
  • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
  • Carefully lift the motherboard up and move it toward the left side of the device.
  • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
