Ana içeriğe geç
Yardım
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left Speaker Replacement
Restore balanced sound to your laptop by replacing the left speaker.
Adım 1 Left Speaker  ¶
Disconnect the two antenna cables attached to the AirPort Extreme card. The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
  • Disconnect the two antenna cables attached to the AirPort Extreme card.
  • The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
  • For the A1261 model, The cable with the black shielding attaches to the left side connector, while the cable with the blue shielding attaches to the right side.
  • If you have a MacBook Pro 17" Model A1229 or A1212, there are three antenna cables attached to the AirPort Extreme card instead of two.
Adım 2  ¶
Remove the single black 4.3 mm T6 Torx screw from the top right corner of the AirPort Extreme card.
Adım 2  ¶
  • Remove the single black 4.3 mm T6 Torx screw from the top right corner of the AirPort Extreme card.
Adım 3  ¶
Lift the AirPort Extreme card up and slide it out of its connector.
Adım 3  ¶
  • Lift the AirPort Extreme card up and slide it out of its connector.
Adım 4  ¶
Remove the two silver T6 Torx screws from the top left 8 mm and bottom right 10 mm corners of the left speaker assembly.
Adım 4  ¶
  • Remove the two silver T6 Torx screws from the top left 8 mm and bottom right 10 mm corners of the left speaker assembly.
  • The magnet in the MagSafe connector may pull the upper screw towards it after the screw has been freed.
Adım 5  ¶
Lift up on the left speaker assembly and rotate it slightly. It is not possible to entirely remove the speaker yet, as it is still connected to the left I/O board beneath.
Adım 5  ¶
  • Lift up on the left speaker assembly and rotate it slightly. It is not possible to entirely remove the speaker yet, as it is still connected to the left I/O board beneath.
Adım 6  ¶
Disconnect the two cables securing the left speaker to the I/O board.
Adım 6  ¶
  • Disconnect the two cables securing the left speaker to the I/O board.
  • Lift the left speaker out of the upper case.
