Ana içeriğe geç
Yardım
PlayStation 3 Fan Replacement
Replace your PS3's single cooling fan.
  • Yazar: Walter Galan
  • Tahmini süre: 30 dakika - 1 saat
  • Zorluk: Orta
Use this guide to replace a burned-out fan on your PlayStation 3.
Bölümler
Aletler
Adım 1 Fan  ¶
De-route the fan cables from under the plastic finger molded into the heat sink.
Adım 1 Fan  ¶
  • De-route the fan cables from under the plastic finger molded into the heat sink.
Adım 2  ¶
Disconnect the fan from the motherboard.
Adım 2  ¶
  • Disconnect the fan from the motherboard.
  • Pull the connector straight up and out of its socket on the motherboard.
Adım 3  ¶
Remove the three 5.7 mm #0 Phillips screws securing the fan to the heat sink.
Adım 3  ¶
  • Remove the three 5.7 mm #0 Phillips screws securing the fan to the heat sink.
Adım 4  ¶
Remove the fan from the heat sink, minding its cables that may get caught.
Adım 4  ¶
  • Remove the fan from the heat sink, minding its cables that may get caught.
