Ana içeriğe geç
Yardım
iPod Touch 4th Generation Headphone Jack Replacement
Replace a broken headphone jack on your 4th generation iPod Touch.
Use this guide to replace the headphone jack on your iPod Touch.
Adım 1 Headphone Jack  ¶
Use an iPod opening tool to pry the headphone jack connector up and out of its socket on the logic board.
  • Use an iPod opening tool to pry the headphone jack connector up and out of its socket on the logic board.
Adım 2  ¶
Remove the single 2.6 mm Phillips screw securing the headphone jack assembly to the rear case.
Adım 2  ¶
  • Remove the single 2.6 mm Phillips screw securing the headphone jack assembly to the rear case.
  • The screw is at a 90 degree angle. Make sure to remove it at such an angle.
Adım 3  ¶
Use an iPod opening tool to gently lift the edge of the headphone jack nearest the battery out of its recess. Remove the headphone jack from its housing within the rear case.
Adım 3  ¶
  • Use an iPod opening tool to gently lift the edge of the headphone jack nearest the battery out of its recess.
  • Remove the headphone jack from its housing within the rear case.
