Ana içeriğe geç
Yardım
Nokero N400 Back Cover Replacement
If anything needs to be repaired from inside the device this step is required to get in to the device.
This guide will serve as a prerequisite guide to accessing the various components of your device and replacing the battery if your battery no longer recharges or will not hold a charge.
Adım 1 Remove Battery Cover  ¶
Press down firmly to remove the battery cover and display battery. Then remove the battery. Then remove the battery.
  • Press down firmly to remove the battery cover and display battery.
  • Then remove the battery.
Adım 2 Unscrew Back Cover  ¶
Remove the 7mm Phillips #1 screw. Remove the 7mm Phillips #1 screw.
  • Remove the 7mm Phillips #1 screw.
Adım 3 Pry Open Back Cover  ¶
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device. Unlatch the clips on the inside and pull device apart.
  • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
  • Unlatch the clips on the inside and pull device apart.
  • Some clips will break when forced open.
