Ana içeriğe geç
Yardım
Kindle 7th Generation Screen Replacement
Distorted images and unwanted lines may be signs of a broken screen. Learn how to replace your screen here.
  • Yazar: Mitchell
  • Tahmini süre: 40 dakika - 1 saat
  • Zorluk: Orta
The screen of your Kindle could be considered the "base part," essentially the part to which all other components are connected. While the repair is relatively straight forward, you will be required to completely disassemble your Kindle. Do not fear though, as this guide will walk you through the steps.
Bölümler
Aletler
Adım 1 Screen  ¶
Remove the two 2.5 mm Phillips Head screws using the T5 Torx screwdriver. Remove the two 2.5 mm Phillips Head screws using the T5 Torx screwdriver.
Adım 1 Screen  ¶
  • Remove the two 2.5 mm Phillips Head screws using the T5 Torx screwdriver.
Adım 2  ¶
Use the plastic opening tool to pry the battery from the back side of the screen.
Adım 2  ¶
  • Use the plastic opening tool to pry the battery from the back side of the screen.
  • The battery has excessive adhesive so this may take some extra effort.
Adım 3  ¶
Run the plastic opening tool around the edge to separate the bezel from the adhesive.
Adım 3  ¶
  • Run the plastic opening tool around the edge to separate the bezel from the adhesive.
Adım 4  ¶
Remove the bezel from the screen.
Adım 4  ¶
  • Remove the bezel from the screen.
  • Use care, the bezel and circuit board are flimsy and the adhesive is strong.
