Ana içeriğe geç
Yardım
Motorola V557 Rear Casing Replacement
Metin kafa karıştırıcı
Bu kılavuzdaki bazı metinler ya kafa karıştırıcı, ya tekrar edilmiş ya da konu dışı. Düzenleyerek daha açıklayıcı hale getirin!
Hatalı İşaretlenmiş
Hatalı İşaretlenmiş
Bu kılavuz için daha iyi işaretler gerekli. Düzelterek ya da işaret notları oluşturarak yardımcı olun.
This guide will show how to separate out the pieces of the lower case to access the logic board, keypad, headphone jack and external speaker.
  • Yazar: Alex Georges
  • Tahmini süre: 5 - 10 dakika
  • Zorluk: Orta
This section will show how to separate the pieces of the main case to reveal the internal components.
Bölümler
Adım 1 Rear Casing  ¶
Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  • Remove the screw covers over the two top screws by prying gently with a pin.
  • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
Adım 2  ¶
Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
Adım 2  ¶
  • Remove all four 6.0 mm Torx screws.
Adım 3  ¶
Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
Adım 3  ¶
  • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
  • Separate and detach the rear casing.
