Ana içeriğe geç
Yardım
Samsung SPH-M360 Casing Replacement
Daha İyi Resimler Gerekli
Daha iyi fotoğraflar bu kılavuzu geliştirecektir. Yeni fotoğraflar çekerek, düzenleyerek ya da yükleyerek katkıda bulunun!
Hatalı İşaretlenmiş
Hatalı İşaretlenmiş
Bu kılavuz için daha iyi işaretler gerekli. Düzelterek ya da işaret notları oluşturarak yardımcı olun.
This guide will show the user how to remove the casing from the back of the Samsung SPH-M360.
This guide will require a screwdriver with a Phillips #0 head (labeled PH0 in iFixit 54 bit driver kit) and a plastic opening tool. Be careful not to lose the small screws involved with removing this part of the device.
Adım 1 Casing  ¶
Remove the four screws on the corners of the casing.
Adım 1 Casing  ¶
  • Remove the four screws on the corners of the casing.
  • The volume and camera buttons may fall out
Adım 2  ¶
Starting near the top of the casing, use the plastic opening tool to gently pry the casing open. The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
Adım 2  ¶
  • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
  • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
  • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
Adım 3  ¶
Once the casing has been fully pried off of the phone, it should be easily removed by hand. The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
Adım 3  ¶
  • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
  • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
