Ana içeriğe geç
Yardım
Samsung Alias 2 Camera Replacement
Daha İyi Resimler Gerekli
Daha iyi fotoğraflar bu kılavuzu geliştirecektir. Yeni fotoğraflar çekerek, düzenleyerek ya da yükleyerek katkıda bulunun!
Adım Kırpıcı
Adım Kırpıcı
Bu kılavuzda gereksiz adımlar mevcut. Az ve öz olması için kırpın!
This is a guide to replacing the camera of a Samsung Alias 2 cellular phone.
  • Yazar: Chris
  • Tahmini süre: 5 dakika
  • Zorluk: Kolay
This guide shows you how to remove a broken camera and install a new camera.
Adım 1 Camera  ¶
Remove the (2) 4.1 mm screws on screen.
Adım 1 Camera  ¶
  • Remove the (2) 4.1 mm screws on screen.
Adım 2  ¶
Remove front outside casing with plastic opening tools. Remove front outside casing with plastic opening tools. Remove front outside casing with plastic opening tools.
Adım 2  ¶
  • Remove front outside casing with plastic opening tools.
Adım 3  ¶
Use tweezers to remove the camera from its holding slot.
Adım 3  ¶
  • Use tweezers to remove the camera from its holding slot.
Adım 4  ¶
Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
Adım 4  ¶
  • Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
Adım 5  ¶
Use tweezers to remove the camera.
Adım 5  ¶
  • Use tweezers to remove the camera.
Adım 6  ¶
Slide ribbon of new camera under the same tab.
Adım 6  ¶
  • Slide ribbon of new camera under the same tab.
Adım 7  ¶
Close the tab down onto the new camera ribbon.
Adım 7  ¶
  • Close the tab down onto the new camera ribbon.
Adım 8  ¶
Use tweezers to put the new camera into the camera slot that previously held the old camera.
Adım 8  ¶
  • Use tweezers to put the new camera into the camera slot that previously held the old camera.
  • WARNING: Do not touch the camera lens as it will easily scratch or smudge.
