Ana içeriğe geç
Yardım
iPod Classic Headphone Jack & Hold Switch Replacement
Replace Headphone Jack & Hold Switch to fix no audio and/or no unlock
  • Yazar: iRobot
  • Tahmini süre: 45 dakika - 2 saat
  • Zorluk: Çok zor
No audio? Replace the headphone jack!
Unable to unlock? Replace the lock switch, which is an integral part of the headphone jack sub assembly.
Adım 1 Headphone Jack & Hold Switch  ¶
Use one hand to hold the orange ribbon cables in place, and peel up the black tape securing the cables to the rear panel with your other hand.
  • Use one hand to hold the orange ribbon cables in place, and peel up the black tape securing the cables to the rear panel with your other hand.
Adım 2  ¶
Remove the two black Phillips screws securing the headphone jack to the rear panel.
Adım 2  ¶
  • Remove the two black Phillips screws securing the headphone jack to the rear panel.
  • These are SMALL! Be sure you have a size 00 screwdriver on hand
Adım 3  ¶
Remove the following two screws:
Adım 3  ¶
  • Remove the following two screws:
  • One black Phillips screw securing the hold switch near the corner of the iPod.
  • One silver Phillips screw securing the other side of the hold switch.
Adım 4  ¶
Lift the hold switch free from its housing on the rear panel. Don't remove the hold switch completely at this time, because it is connected to the same cable as the headphone jack.
Adım 4  ¶
  • Lift the hold switch free from its housing on the rear panel. Don't remove the hold switch completely at this time, because it is connected to the same cable as the headphone jack.
Adım 5  ¶
Slide the headphone jack out of its housing on the rear panel.
Adım 5  ¶
  • Slide the headphone jack out of its housing on the rear panel.
  • Lift the headphone jack and hold switch assembly out of the iPod.
Adım 6  ¶
If you're just trying to remove the rear panel, you can skip Steps 30 and 31. If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
Adım 6  ¶
  • If you're just trying to remove the rear panel, you can skip Steps 30 and 31.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • Remove the single Phillips screw nearest to the hold switch.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Adım 7  ¶
Use the small iPod opening tool to carefully peel the orange ribbon cable and attached black Hold switch up from the metal backing.
Adım 7  ¶
  • Use the small iPod opening tool to carefully peel the orange ribbon cable and attached black Hold switch up from the metal backing.
  • When re-attaching the replacement Hold switch, make sure the two small posts on the back of the switch are aligned with the two holes in the metal backing.
